Here’s the ARP bolt torque specifications.
arp-bolts.com
I see 24 ft.lb.
Thanks for posting thatHere’s the ARP bolt torque specifications.
I see 24 ft.lb.The Official ARP Web Site | Metric Bolts
arp-bolts.com
You are welcome.Thanks for posting that
I have rubbish internet so searching for a good clear chart was never going to happen
My guess it is a bad translation
Thread shear on a 10 x 1.5 mm bolt is 42 ft lbs but the alloy will yeild way before that 30 to 35 ft lbs depnding upon composition & temper .Considering that very few mowers run anything like high compression those published figures have to be wrong .
Naw, you are supposed to zip them down with the impact and give it 4 ugga duggas.Thanks to all! I've worked on 100's of small and large engines but always able to get good specs that I can trust. But getting info on this engine model has been difficult and somewhat not reliable. ALL of you have pointed me in the right direction and is much appreciated! (BTW.... I use a calibrated snap-on torque wrench that is checked every year) But if manufacturer is putting out inaccurate specs, it doesn't matter how accurate it is if your not applying the correct spec! With the new bolts, I'll put them at 33 ft Lb and use anti-seize compound.
Also, a local Toro dealer told me to just tighten them equally and go 1/4 turn further! I knew better!
