7394
Thanks for the good catch, I had a Muncie car tranny in my head from earlier.. I stand corrected, & edited my post.Close on the threading but it is M20-1.50 instead of M21-1.50
And I found it to be M20 - 2.50
Agree. As I recall, the Kawasaki engine was the only one for that model. Which is the engine I wanted anyway. Yeah I plan to cut off that stupid effing Barbed T and then unscrew what’s left of the POS fitting.The Dealer would probably tell you, have to remove the engine bolts & raise the engine to remove the POS poly-plastic drain. but likely they would just saw off the barb, then charge for that the whole deal....
Doing same thing on my Liberty w/Kawasaki engine..
Yep, cut that barb off, & that was the only engine I wanted as well. I have same engine in my Liberty also. They should have came stock with the flex hose.As I recall, the Kawasaki engine was the only one for that model. Which is the engine I wanted anyway. Yeah I plan to cut off that stupid effing Barbed T and then unscrew what’s left of the POS fitting.
Thanks!Yep, cut that barb off, & that was the only engine I wanted as well. I have same engine in my Liberty also. They should have came stock with the flex hose.
For POS removal, (Drain all oil 1st of course) You will likely have to loosen the IIRC 1" lock nut against the engine so you can rotate the POS plastic drain to un-thread it, but would suggest cutting barb off 1st..
Use a bit of grease on the O-ring on the Flex hose, B-4 install. So it doesn't chaff it.. then after, Enjoy !
Thanks!
p.s.……..that POS tee is already loose. I guess I’m lucky LOL.
My Subaru has upside down filter to, I punch a hole in top of filter with screwdriver to drain before removingThere ought to be a special hell for certain people. (1) Those who design oil change set ups with ridiculous arrangements. One example, My old Tacoma had an upside down filter....duh...but they did have a little moat sort of arrangement with a nipple on which you could put a drain hose that only a 5 year old could snake through the suspension. (2) People who make the bubble packaging. They need to go through eternity with cuts and scratches all over their hands. (3) And these days, cars that talk to you.
that's where a reciprocating saw comes in handy.Seen many a mower where the supplied engine had an original long oil filter that an not be removed without moving the engine.
