L LPservices Forum Newbie Joined Jul 22, 2013 Messages 1 Jul 22, 2013 #1 Need help on replacing the blade brake clutch belt on this mower. Can't seem to get it around the pullies, checked and have the correct belt #.
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,271 Jul 22, 2013 #2 Belt number is 42-0884. Unless you are experienced in working on the Toro drives and BBC, I would not advise you to attempt changing this belt. You must disassemble and reassemble the BBC system to install the blade.
