Toro Recycler Model 22198
LPservices
Need help on replacing the blade brake clutch belt on this mower. Can't seem to get it around the pullies, checked and have the correct belt #.
Belt number is 42-0884. Unless you are experienced in working on the Toro drives and BBC, I would not advise you to attempt changing this belt. You must disassemble and reassemble the BBC system to install the blade.
