AWilkie
Hi folks.
Mower hasn’t ran for a while. Prime the carb and it fires up and runs then will slow down and then stop. Tried loosening off the fuel cap incase it was a vent fault but no difference. Cleaned fuel system and carb but still the same. Noticed no fuel
Coming up when primed so decided to change the carb but still the same. Also removed the exhaust incase that was gummed up.
Anyone had similar and came up with a cause please. Thanks all.
