Toro Recycler 6.5HP has crimped cable
villeguy
The cable that activates the self-propel feature of my Toro mower has somehow developed a crimp (see photo). It does not affect the mower's performance, but I'm wondering if and how I should straighten it out. Any advice is appreciated in advance.
Been there, done that, I don’t worry about those unless they have a crimp in them. A little on them once a year will serve you well.
Push bike dry control cable lubricant is best because it does not gather dust .
Not chap but I only use a 4 oz bottle every 5 years and I use it every day
Do you recommend that I just leave the cable crimped? Or is there a way to straighten it?
And do I just squeeze the lubricant up top, where the cable sticks out of the rubber tubing around it? (You can tell I'm a novice.)
Thanks to both of you, R & B, for your advice.
You can push that cap up and push the lube into cable and push the cap back down.
you go to a motorcycle shop. They sell a kit that lubes cables. You can try to straighten it with your thumb but it is not that hard to replace. It probably happened when the handles were folded.
