Cbrjoey
I'm wondering if I can get some help I have a Toro mx4250 with approximately 550 hours on it. The problem I have at the moment when I go to start the mower it acts like it has a flat battery. I've gotten used to holding the key turned and usually within 3 seconds it will start. This mainly Happens Only when it's warm. I've changed batteries tightened all the leads also change the solenoid for the starter motor and the PTO switch for the blades. I don't know what to try next. Thanks in advance.
