Toro mower won't start without starter fluid
jonsi
Hello, looking for some help. I have a Toro mower with a Briggs and Stratton engine, no prime, bought it in 2012. It won't start without the help of starter fluid. Once its started it runs fine no issues until I turn it off and try to restart it. The starter fluid works every time. Ive cleaned the carburetor a couple times, checked the spark plug and it looks fine. Any ideas on what the issue might be? Spark plug?
reynoldston
Toro make a lot of different model and style mowers it would be helpful to have a little more to go on.
jonsi
Its a Toro Model 20334 Serial 310013554
Briggs and Stratton 128T05-3123-B1 09122957
Thanks
Time to rebuild the carb, float level has changed, not allowing enough fuel to enter the bowl.
