Hello, I just found this group and am glad I did. I saw that back in 2014 someone else had a problem similar to mine but not exactly. I have a 2008 Toro Groundsmaster 3500D with a Kubota Diesel that I purchased used about a year ago. It has about 3500 hours on it but has been expertly maintained and looks almost new. I love the machine but it has recently developed a problem and I'm hoping someone on here can give me an idea where to look. The mower runs fine all the time except when going down hill. If the hill is steep enough the engine will die. It acts like it's running out of fuel. It will restart with no problem and as long as I don't go down hill it will run fine. I thought of fuel delivery issues but the fact that it only does it when going down hill baffles me. The tank is 3/4 full and the filters are almost new. The lift pump runs steadily and I'm no expert on diesels but would like to know if anyone could explain why a failing injector pump would only do this going down hill? Any advice would be greatly appreciated. Thank you.
