I have a 60” zero turn that keeps blowing 30 amp fuses. It just started doing this after sitting a month. My guess from reading some other forums might be a bad pto clutch but I just replaced the clutch so?? I ordered a new solenoid thinking that was it because I can short the solenoid and it turns over. Doesn’t start but turns over. It still blows fuses even after installing the new solenoid. There is snow on the ground and it’s below freezing. I can’t use it but want to fix it. It’s in an outside shed and need to wait till it gets a little warmer to work on it. But want to see if there are things other than the solenoid that I should be looking at?
