- Nov 29, 2014
- 24,995
Which one Bert ???? The LC1P92F-1 in my link ????
You know more about those engines more than I do ...... I may have worked on a Loncin engine a few years ago for a friend of mine.... It didn't have any name stickers on it and it looked like Chonda engine... All I did was clean the carb really well and as for as I know it's still running.....
Like I said before I have no idea about those engines......Just giving out a link for parts.....
Plus Tard Mon Ami ............
When the new Time Masters started coming in I had to find information on them
It was right there on Toro's web site like all the information you ever need for repairing anything Toro ever made once you find the right numbers to plug in.
Prior to that I had been using the parts breakdowns from Loncin's web page and ordering parts from RGS
The Loncin site carries the base model parts breakdown.
The carb , air cleaner, governor arm & springs and engine plug are all different on the Toro branded engines.
The biggest problem was the plug as I had to do some rewiring being that I do not have the round terminals & plugs as down here we use spades.
Can not work out what the difference in the carbs is, nothing apparent apart from the manifold .
I would hazard a guess that the Toro branded carb was a bit leaner & EPA compliant.
The throttle control plate on the replacement Loncin engines does connect to the TORO engines.
They swapped right over just the same as yo might have to do when swapping an engine from a AYP mower to an MTD mower.
WE get a lot of mowers direct from China.
They come here and get rebadged to local mower companies names & store brands.
A lot of them are as cheap as $ 750 landed so all of what used to be made for the local market by AYP , MTD or Murray now come direct from China
I can see the logic , $ 750 then a few stickers and it is $ 1300 into the retailer and $ 1999 to the customer.
Nothing imported from the USA can come close to those prices locally.
Manual PTO McCulloch , Craftsman & Poulans start at $ 3000, in fact JD's are the best bang for your buck down here where I gather over there you pay a big premium for the green & gold.
