Hey folks. I have a Toro 2006 Z400 with a Kohler Command 18 engine. I have had what seems to be nothing but problems with this mower. I only have 166 hours total on this mower.
I recently had to have the engine serviced due to a massive oil leak and suspected oil/fuel mixture causing the engine not to start. Now the engine starts just fine, however the other day when mowing the blades just stopped. The belts are good. I suspected the relay, however I can hear the PTO relay click when I turn on the power key and pull up on the PTO switch.
Does this look like a clutch issue? Every now and again it will start. The fuses on the side panel also look good.
Any help or tips are appreciated!
