The type of flywheel puller will depend on the type and size of the engine you are working on. Briggs has three different size pullers, well actually four, but that last puller is for the briggs engine with the 1500 watt generator build into the flywheel/stator. Kohler had their own puller, but it looks like a steering wheel puller. I have used that puller for Kohler, Kawasaki, and a couple of other brands, could be used on briggs to I believe.
