I am pretty sure I understand how to adjust the valves. I am good with that.
So after watching a couple videos, I am wondering if the compression release and cam shaft are not working properly.
when starting the engine it gets caught up on the compression stroke. I need to double check, but I think the bottom valve does not move like the top valve.
The engine is almost 20 years old and I got it used.
Could I have a cam shaft/ compression release issue? How would I know for sure?
It's very possible because the ACR on these Briggs & Stratton engines is an absolute joke! They should have fixed the problem long ago but Briggs basically refuses to fix anything of their inferior quality designs.
Don't get me wrong, I love Briggs & Stratton engines, some of them. I just call out what is crap.
I don't know why people want to insist on applying normal valve train and car valve train to these engines.
Don't do it!
Don't do the set one valve while the other valve is closed and all that crap.
It's not a car!
It's a low performance little turd mower engine so do it the way the manufacturer designed it to be set and designed it to work.
It is very simple.
Turn the engine over by hand until you get to top dead center on the compression stroke and then turn it until the Piston goes down at least one half inch past top dead center.
Now in reality, like I've told people for years, you can go a lot further than that and you can actually go all the way until almost bottom dead center until the exhaust valve starts to open so you have a lot of leeway there but the point is you need to get past top dead center!
So get the Piston pass top dead center and down an inch or an inch and a half and you're good to go setting both valves.
Now, I also don't know why people get into setting them at different than Factory spec clearances or making them more loose like they're giving some extra margin of safety.
I understand that unexhaust valves or any valve that could burn which is typically an exhaust valve, being closed longer is better so in this case more clearance is better but that's just not necessary!!
Set the darn things to watch the book calls for!
They already give you .002 a variance from Titus to loosest for each clearance so if you feel the need to go to the high side that's fine but don't go .008. when the spec is 005-007.
I know in reality it's not that big of a deal but come on people...
On the intake you should go on the tight side to get as much out of the ACR as you can.
The reason you don't have to go any larger even on the exhaust is because these things do not wear tight like a car or like many other engines.
You would think they would as the valve margin on the seat erodes and the valve stem tip effectively gets longer but that's just not how these work.
What happens 10.5 times out of 10 is the rocker arm tip and the valve stem cap and probably the push rod tip also or at least the rocker arm pocket it sits in wear away a little bit of metal so the clearance gets greater which means looser.
EVERY time you pull one of these engines apart that's been together for a while you will find these clearances at .010 to .016 etc.
Now that I'm off my soapbox.. the way to see if your ACR on the camshaft is busted is to adjust the intake valve correctly or just set it to zero lash where it's touching for test purposes and then turn the engine over by hand or spin it with the starter.
You will see the intake valve open and then close and immediately after it closes it will bump open for just a split second.
We call it the bump.
If it doesn't noticeably bump open slightly then your ACR is busted.
There is a workaround for this though and that's to take your air filter off and turn the engine backwards counterclockwise with your hands until it gets to the hard spot again. Then hold your hand over the air filter intake so you block off all the air. You should probably also have the choke closed when you do this...
This will make the engine easier to spin over because it won't have as much air inside of it to compress so it won't be compressing so hard.
I have been able to get everyone of these to start just fine this way and then of course they will mow fine it's just starting them that's hard.
It's not ideal because you do have a couple of little pieces of metal in a spring laying there and your base plate but oh well.
I replaced the number of these and I started out using all Briggs & Stratton brand parts and then I migrated over to the off-brands on eBay and Amazon and did three or four of them without any problems.
But then, last year I had major problems with one that failed in just a couple of months with only five or six mows.
It didn't fail the way the ACR fails but the cheap metal press on lobes and the splines on the shaft just stripped off and it got out of camshaft timing for the valves.
This made me afraid to use any more of them and if you read the reviews they are absolutely horrendous..
So I replaced it with a Briggs & Stratton with the new upgraded part number and so far it's been fine.
