Tires... where do you get yours?
The Chairman
I'm in need of a 20x12.00-12NHS tire and/or tube. I have a cut on the outer tire and while its a series of holes, I'm not sure a tube will fix it. No one local seems to have the tube or the tire. My local dealership will have tubes in on Thursday, but I'm thinking the entire tire needs to be replaced.
So where do you go for tires???
Hello,
I've bought front tires for my Kubota BX2230 from Family Farm and Home and TSC. They are Chinese made (same manufacture from both stores) and haven't been happy with them. They started leaking air from the getty up.
Regards
Jeff
Carlisle if i can get them. Had good luck with Kenda and chen shin. Had bad luck with some of the ebay chinesium ones. Beads leaked no matter what even with bead sealer. Ususlly get tires from stens
I found and ordered two tire and rim assemblies for $69.95 shipped to me: MowerPartsGroup (2) Hustler 20x12.00-10 Wheel Assemblies Fits Hustler Raptor SD 54" 60" 601349
Thought you looking for tires for 12" rims which are not available in 20" as far as I can find. Those are on 10" rims. Got to be some really cheap made Chinese tires and rims.
I was, but these are Carlisle tires and they're still 20" in diameter and 12" wide. The smaller rim means a taller profile on the sidewall and that should result in a softer ride. I'm all for a softer ride. I'm going to put a tube in the old tire and now I'll have two sets of rims and tires.
The 20x12.00-12 are hard to find, but they're out there. Anywhere from $70 to $170 per. That's car tire pricing. I'll let you know how the match up when I get them.
OK, don't follow my link. In a classic bait and switch, after almost a month, they sent me a pair of Rayban Sunglasses. Amex called and I should be getting my money back.
