Tire replacement
Ande3528
On my John deere la105, the rear tires are about dry rot right off the wheel. I've been searching high and low for a cheap set. I was wondering where you guys have had luck with finding good prices? Suggestions? Advice?
Tire size is 20x8.0x8
There are none so don't knock yourself out looking .
Mower tyres are low volume & bulky to boo so the prices will always be higher than car tyres where a factory will make more in any one size in a day than they make all year for mowers.
Cheap tyres are made from high lattex rubber and rot very quickly if left exposed to UV .
Scrubcadet10
Moderator
Staff member
think these will work?
Type in 20X8X8 turf tire in google and you’ll find plenty.
Born2Mow
My local Tractor Supply keeps a fair stock of mower tires.
