Those are 16-20psi tires, not 9., unless they are Turf Savers 2ply (which they dont look like), then they are 10psi.
edit: What the name/product code on those? Looks like a Turf Master..
I am assuming you are using a low pressure tire guage.
I couldn't read a product code the way both tires are down and creased, but I did read 4-ply, inflate to 20 PSI with the name LITE FOOT or something, I did not see the word Turf Master but again it is difficult to see in the shed.
So bottom line, why is there a 9 PSI sticker on my rim with tires that obviously need more # of air?
Anyone else heard of it causing transmission damage or is the tech at the dealership who gave me the info on how to start, etc. when I picked up 329 just mistaken?
I have not broken a bead yet, but on this one wide hill that I mow sideways it does feel like it could bust a bead.
I have no idea why its there, but those tires are way too low. If they are not Carlisle Turf Masters, then they are a knock-off/same thing w/ a different name. If you can, go back to the dealer and look at other 329's and check the tire's over all height as sitting. This is the most important measurement as it determines the circumference which determines the 'rotations per miles', which determines the speed at a set RPM. In effect, your final drive ratio and how hard your hydros work. Speaking of which, I am not familiar with Grasshoppers all that much, but maybe you have an upgraded model with bigger hydros, more weight, and thus better tires?
