Yes I got inside engine put new rings in sorry if I didn't make it clear. Thanks!Did you just take the flywheel off it did you get inside the engine
I got in side engine!Did you just take the flywheel off it did you get inside the engine
numbers on engine are 287707 0220 01 9308044aSorry I worded it wrong also.
Can you post the engine model numbers and I will tell you how to line everything back up.
Ok I think I have it. as long the piston is at top dead center on any stroke is this right?I know this is not what you have but it's close.
Just like in the pic line up the dashes with the piston at TDC
If you need I can take one apart when I get home so you can have a better idea
I'm still confused with piston at top dead center marks don't line up. But if you line up dots on crank and cam one way but if you turn engine one circle the dot on crank is across the cam on other side. Sorry I don't no what I'm doing. Please help me can't aford a new mower. Thanks Joey!I know this is not what you have but it's close.
