graybeard47
This was posted on 10/01 titled:
Before chasing parts one by one, I would like to determine if the timing belt has broken. I do not know what the signs are that in fact it is. What are the steps to at access it for a peek at it.
Forum thoughts as to this direction.
GVC 160 Model 917.376542 Now Will Not Start ( It started just fine again on the 1st pull of the pull cord for about 8 months after a good cleaning with CHEM-DIP solution)
I received a reply to replace the spark plug with the same results: As before----"any pull on the start cord results in a couple of pops out of the exhaust."Before chasing parts one by one, I would like to determine if the timing belt has broken. I do not know what the signs are that in fact it is. What are the steps to at access it for a peek at it.
