Timecutter Z5035 drive issue
Gatorman17
I have a 10 year old Z5035 Timecutter model # 74376 that has preformed flawlessly. Recently the left/right turns have started to become more strained (as if a drive belt was slipping). The turning becomes much more labored when I am at a stop or going slow more so that if I am moving a few MPH. Any and all suggestions would be appreciated.
When was the last time you changed the drive belts and checked the idler pulleys? Depending on usage, belts should be changed every 3-5 years and pulleys checked every year.
Gatorman17
Thank you very much. That was the initial direction I was heading.....
