While you are mowing your deck is being bounced up and down all the time.
And vibrations can cause welds to break.
How did my 54" deck on JD 345 end up 2" higher (or lower) from side to side? Don't remember hitting anything.
Doesn't appear so. I've had tractor since new 1999. The deck was new 3-4 yrs ago. Was working fine. I just cranked up nut to lift assembly to where I've got same clearance to ground on both sides at this time. Next mowing session I will see what I've got then, I guess. Thanks for your inputs!
Sjb[/QUOTE
Update: above adjustment apparently made difference !! Thanks for all input!,
Sjb
