- Nov 29, 2014
- 24,995
FWIW
I generally adjust the L with the H closed up fully as in theory only the L is in use at start up
IF it won't start like that then the throttle stop has been wound in too far holding the throttle too far open
Once I have it starting reliably then I play with the H
Wound out till the engine just starts to miss then in just enough to get it to run clean
Thus it will usually be a little rich
Also the head must be on and the full length of string must be out to loa the engine .
