Jeff Klink
- Jul 24, 2024
- 5
Thank you, again. 50-55 foot pounds of torque it will be if all before that step goes well. It was cumbersome to try to hold the shaft from turning with a channel lock while unsuccessfully trying to loosen the bolt with a regular socket wrench as the shaft would still turn. I discovered the shaft has a small hole in it above the mower-belt pulley that may temporarily accommodate a small screw and, if so, render use of the channel lock more effective in keeping the shaft from turning, particularly against no more than 50-55 pounds of torque. Thus, assuming I have better luck getting the bolt off with an impact wrench, in tightening the bolt with a torque wrench, the temporary screw and channel lock will hopefully counterbalance the required torque without the shaft turning. At least, that's my current plan. Thanks, again, for your time and expertise to date.
