Long story short. I have recently replaced both pumps with oem hydro gear pumps. I have also replaced the right side wheel motor with after market wheel motor.
I have no leaks and have purged the system by raising rear of mower and running fill fwd for 15in. Full rev for 15min with bypass valves open smd repeated the process with them closed. I then went and started to mow. I noticed that it felt weak going up hill. while I continued to mow I noticed that if you go full fwd, it actually looses power. If you pull back a bit and work the levers it will go up but will stop before it spins the tires.
I thought that if I ran it for a while it may clear up but there was no change and I mowed for about 4 hours.
Any advise would be appreciated.
