shiftsuper175607
- Sep 11, 2013
- 10
- 1,000
Thanks for the tips - some troubleshooting over the weekend required.
It is probably the clutch end as all the spindles, pulleys and idler pulleys have been replaced on the deck.
When the belt snapped - I tried turning the clutch pulley and there was quite a bit of resistance. Is this normal ?
You sound like you are disregarding the possibilility that it is spindles, pulleys and idler pulleys because they have been replaced.
There could be one installed wrong...I would recheck them.
What about belt routing?
