jekjr
- Jan 3, 2013
- 1,969
Hi. Glad I found this thread. I just purchased a new TC2 52" Kawasaki last fall but my mowing started this year. I'm particular about a nice clean even cut, which is why I went with this mower and the velocity deck. But I don't think it's cutting like it should, especially around the tire track area. Like someone else said here, I have to double cut in order to make it look nice, but even then, I can find some flaws. On slopes, it will scalp on the low side. I've cut anywhere between 3.5" to 2.75", I've gone slow, but like someone else said, it might cut better going a little faster. The only adjustments I've made has been with the baffle. I lowered it 1 notch to create more vacuum(?) and thought it helped some, but not sure. I slightly over inflated the rear tires to 20lbs, but that really hasn't helped.
I can post pics, but I think my WI yard is a mix of rye, fescue and Kentucky Blue grass. My yard is pretty thick since it is irrigated and gets (3) fertilizer treatments yearly.
So how, or what is the best way to check for a level deck?
Ideally, should it be 1/4" lower in the front?
What is the proper position of the anti-scalping wheels?
Would high lift blades make a difference?
Should I raise that baffle higher?
Thx!
The higher the baffle the better it will cut tall stemmed grass. The lower the baffle you will get less blow out cutting with a mulching plate. I have never taken a baffle out but I am seriously considering doing so.
