Ric
- May 7, 2010
- 5,765
blade tip speed is actually faster on the 54, but not enough to make a difference.
and the bars dont move up or down. just fore and aft.
and unless your yard is wide open, i'd probably go with the 54 which will be a bit more manueverable.
Seat Adjustment
The seat on the HustlerRaptorSD mower can be adjusted forward and rearward by pivoting the seat platform up and forward. Then,loosen the four cap screws on the underneath side of the seat platform. Position the seat where you have the best control of the machine and are the most comfortable and then tighten the cap screws.
Steering Control Lever Adjustment The steering control levers can be adjusted for operator comfort. By loosening the cap screws that attaches the upper control lever to the lower lever (Figure 4-13), the upper control lever can be pivoted to fit the operators personal preference. The steering control levers can also be adjusted up and down. Remove the cap screws and slide the upper control lever up or down and align the holes in it with the holes in lower lever. Re-install the cap screws and tighten.
The steering control levers should be adjusted so that they
align with each other when in the neutral position
