P PGMike Forum Newbie Joined Oct 11, 2012 Messages 3 Oct 11, 2012 #1 Does anybody have any feedback on this mower....positive or negative? Have about 9000 sq feet of St. Augustine and was wondering if this might be a good choice? Thanks
lawn mower fanatic Lawn Pro Joined Jun 8, 2012 Messages 6,749 Oct 11, 2012 #2 Your yard is not too big for an electric mower, but there are 2 other things that you should consider before buying: How others like it (a.k.a. Any common problems, etc.) This is an electric mower, so you are not going to have the same cutting quality as a gas-powered mower. Personally I think it will get the job done just fine.
lawnmowerleader Member Joined Jan 15, 2013 Messages 13 Jan 16, 2013 #3 Good mower and this is some of their features Adjusts height of all four wheels at one time with the pull of a lever Provide a great looking lawn No more starting issues freedom of a gas mower with the convenience of an electric mower. It is simple to start and requires no gas, oil or tune-ups. Charge away from mower for convenience or swap in additional batteries for larger lawns
MowerMike Well-Known Member Community Leader Joined Sep 5, 2012 Messages 976 Jan 18, 2013 #4 @PGMike - Read the following thread; it may change your mind: http://www.lawnmowerforum.com/elect...-blade-li-ion-battery-powered-lawn-mower.html Note that the Greenworks twin blade mower weighs 47 pounds, which is 45 pounds less than the B&D SPCM1936.
