- Nov 29, 2014
- 24,995
Check that the cut off solenoid unde the carb is working.
It should give a reasonable click. on and off as you turn the ignition on & off.
If your ears are not as good as they used to be you should also be able to feel it but unless you are cover with orange hair you will need another person to work the switch.:smile:
You can also remove the float bowl under the carb but put a catch dish under it to catch the fuel.
You are looking for dark coloured foul smelling fuel or water.
