Transmission upgrades?!?!?! I know I would have to switch belts to chains... but why transmission? :ashamed: Hmm how should my shop setup be? :confused2:
You'll typically have to at least remove reverse out of the peerless tranny for durability reasons. Also, seals and bearings get upgraded. More info at www.heymow..com
As for shops; the sky is the limit! My dream shop would have a couple of old forklifts, converted to run on electricity to get machines up in the air, a big bench grinder, blast cabinet, powder coating equipment, all the welding equipment, a steel rack, tire machine, lathe, milling machine, small spray paint booth, two or three large MATCO toolboxes with all the hand and power tools, good lighting, heat, painted concrete floor...well, you get the idea by now.
