Well...my Honda HRR's back wheels are completely done I think! They were smooth since they had no tread, but now they are getting holes...that's how far they are worn down! :confused2: Luckily I get my HRX back tomorrow! :thumbsup:
Curious, any idea how many hours of use you got out of that set of wheels?
So my yard is 100X300 minus the house and paved areas. I can cut in well under 2 hours, summer time its 1.5 hours. Figure 30ish cuts a year. That would be under 50 hours a year. (Actually in my case its much less as I use my Honda for trimming and full cuts only in the spring and fall or after heavy rain) So you are talking about 10-15 years of residential use. That is some pretty good wear on those tires.
Should have got a
S
N
A
P
P
E
R
(( racing is the only sport that you need two balls ))
I find it interesting what you said about the drive failing... my snapper(walk behind) does not get much use now.. but when I used it alot, it started this thing where it went forwrd but would not back up... turned out I had been neglecting the drive tranny oil. Checked it and it was low, refilled it and started changing it every so often and it never happened again.
You can not buy a better push mower than a snapper.
Every one else has tried and make a better cutting mower and has failed.
They are still the best mulching and bagging mower
I know some will agree and some will disagree, but I think Honda mowers are some of the best mulchers around. I think Honda, Toro, and Snapper are the best. :thumbsup:
I disagree. I think honda motors are great the rest is kinda junky (look at your wheels) toro is cheap there are so many models with so many different features with every possible price and mostly what I've seen has been garbage. Commercial toro is good. I have no experience with any snapper.
Now I do not like their riding mowers. But if I ever was to get a zero turn it would be a snapper.
I think I would have to agree with this, in most cases. I REALLY like the self-propelled, so many speeds, and so simple. I also love the thick steel decks, my Snapper I started my business with (Ha, one yard a week, plus my own) looks nearly new, besides some dirt and an off-shade of red. They are fantastic side dischargers, while most just spew out clumps of cow chow, these spread a thin layer of fine blades of grass. And finally, they SUCK! Now by suck, I mean in a good way. They really are HI VAC. While mulching, you can turn most leaves into a fine dust, and while side discharging you can clear sidewalks in seconds. You can actually see the grass being pulled from the concrete.
Now I do like the Honda mowers even though I only have one. They are great mulchers, and I haven't even heard mine get bogged down in tall grass yet, and the four lawns I mowed with it so far this week had some pretty tall grass. But the mower just purrs right along. Now it didn't cut too great in the tall stuff, but that is pretty common, so whatever. The wheels on my mower happen to be beautiful, with tons of tread, but then again that may be due to the fact that the transmission is shot:thumbdown:. (or at least has issues)
Toro, ehhh. I like them, but not that much. The ones that I have used mulch great, but it just seems like they are missing something. Now I do like my older Toro with a Suzuki 4-cycle. Although it seems to have no compression, it runs great, and cuts great as well. I'm currently in the process of repainting it (thread to come later).
So if anything, I think that a Snapper Hi Vac deck, with a Honda engine would be the best mower ever.:cool2:
You really think that Honda mowers are "junky" based on tires that wore out at 500-700 hours? (with many street miles according to LMF)
Its their lower end homeowner mower being used commercially, if anything I think it proves that its one hell of a mower.
And I can attest that the Honda (at least the HRX) is a very good mulcher. And that it mulches way, way better than the Toro Recycler that I had before. Its no comparison.
I do love the Snappers, I still wish I had one. They priced me out of the market though.
They wear out at about 100 hrs he just let them go for that long. They use inferior parts at lease on the hrr seems like the parts they use is to make the hrx look that much better.
Oh and lmf I believe that thing on one side is either blade or drive not throttle
Now this may have been true years passed but not anymore. To many Company's too many mowers that are way ahead of Snapper. I kinda view Snapper like the Honda, they make a good mower yes and they have proven themselves in the residential market but until I see them being used in the commercial market I don't believe they are all that great a mower.
I feel like wheels are wheels. They wear out, either around the bolt, or the tread, and you have to replace them. You replace tires on your car every so often, and I don't see a difference with doing that for lawn mowers. Maybe we need some good pneumatic wheels, or even wheels with metal tread!:thumbsup:
The best 21 for commercial in my opinion is the toro proline. Hands down.
Well what do you think is the best 21 in. push mower for the commercial operator?
Cutting Options 2-in-1 (Side-Discharge/Mulch)
Material 14-Gauge
Construction Welded
Blades 1 Blade
Positions 7 Positions
Cutting Height 1.25-4.0 Inches
Front Axle Stamped Steel
Front Tire Size 8 Inch
Rear Tire Size 10 Inch
Tire Type Solid Rubber
HP/CC 190 cc
Torque 8.5 ft-lbs Net Torque
Fuel Tank Size 0.25 Gallon
Cycles 4-Cycle
Oil Filter Yes
Snapper CRP218520 (21") Commercial Ninja Self-Propelled Mulching Lawn Mower
Only $650.00.
Engine | Kawasakiョ FJ180V 179cc Commercial |
Fuel Capacity | 1 Gallon (3.8 L) |
Mowing Speed | Variable up to 4.1 mph (6.56 kmh) |
Cutting Width | 30" |
Height of Cut | 1.5" to 5" in 0.5" increments (38 to 127 mm in 13 mm increments) |
Number of Blades | 2 |
Starter | Recoil |
Deck Material | 13 Gauge Steel |
Mulch, Bag, Side Discharge | Standard |
Weight | 167 lbs. (dry, mulch mode) |
Warranty | 1-Year Limited Commercial Use 2-Year Limited Commercial Use Engine* |
Bagger Capacity | 2.5 Bushels |
Blade Design | (2) .135" thick steel |
Blade Engagement | Blade Stop System (BSS) |
Blade Tip Speed | 18,000+ ft/min |
Engine Displacement | 179cc |
Height | 27" |
Length | 37" |
Spindle Housing | Die Cast Spindle, 17mm cold formed spindle shafts |
Tires | 8" x 2.25" front, 10" x 3" rear rubber tires with co-polymer wheels |
Transmission | Variable Speed, Rear Wheel Drive |
Width | 33" |
I agree as far as walk behind and and zero turn mowers and especially for golf course or sports fields toro is number one ( I have a few toro mowers )
When it comes to a 21 inch push mower I still like snapper. ( do not like snapper rer )
Material 14-Gauge
Construction Welded
Blades 1 Blade
HP/CC 190 cc
Cycles 4-Cycle
Oil Filter Yes
Only $650.00.
<img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=16008"/>
I do like that mower and the price tag is good to. Is this the model that has the tube out the side into a bagger? Also does it have a bbc?
No BBC and no side tube since it's a Ninja Mulcher. I was thinking about getting this mower.
I wish it could bag or I would probably buy it.
Ok here's the deal but don't tell anyone
You can get a kit so you can bag.
If you ever get one I can look in my files and get the part number.
Now snapper will tell you they don't sell a kit for this mower but they do
The thing is as far as top rated mowers go you can visit ten different places and get a list of the top 10 rated mowers on the market and every list will be different and have different mowers.
If you are talking about that ninja CRP218520 it comes with a bagger? My problem with buying the mower is the fact it only has a 90 day commercial warranty.
What I think are the best commercial mowers on the market right now would be, I'd have to say The Toro and Exmark with the Kawasaki engines. The thing is as far as top rated mowers go you can visit ten different places and get a list of the top 10 rated mowers on the market and every list will be different and have different mowers. I think if you honestly want to know what is the best the way to find out, is watch the professional maintenance crews on some of the golf courses, or that maintain these 2000 home sub-divisions and see what they are using. Talk to some of the owners and ask why they run what they have and why.
But Honda is consistently on top. :licking:
- Best Self-Propelled Lawn Mowers - Top-Rated & Best-Selling Self-Propelled Mowers
- Best Lawn Mowers - Top 6 Lawn Mower Reviews
- Consumer Reports: Honda Tops List Of Lawn Mowers For Performance, Value - Hartford Courant
"Consumer Reports' latest mower tests show that Honda is on a roll for performance and value. Testers also found some bargain-priced riders, including two new models from Troy-Bilt that turn on a dime and are as close as your nearest Lowe's.
Honda took four of the five top spots among the multispeed, self-propelled mowers most people buy. But you don't have to buy the $700 HRX217VKA to get a stellar machine; the brand's new HRR216VKA costs $479 and scored just two points lower overall. A well-placed bump beneath the deck helped it ace the mulching tests by sending clippings back into the blade. And like the other new Hondas, it toggles between mulching and bagging with a flip of a lever."
I understand commercial warranty's but really commercial users (the smart ones anyway) are kinda small engine mechanics as a side effect and a warranty while nice but unnecessary because most problems can be taken care of by the user. I believe you should not run a lawn care business if you cannot fix and maintain your machines properly.
Warranty is good for the person who does not know how to fix things. This is one of many reasons I am ok with residential quality equipment as I can fix just about anything on them. Also my entire trailer full of equipment can be replaced with 1 grand easy if something crazy happened. The snapper here looks like a good quality machine and its in my price range (easily replaced) and its on my radar if and when my honda actually dies.
I agree with what you say but the warranty is not about fixing your mower or how good you are with fixing things, it's about replacement. A year ago july 4th I purchased a Toro Grandstand, now lets say next month I should have a drive unit or a PTO go bad, or the motor goes bad, who's going to pay for that? With the 5Year 1200 hour warranty they pay for everything, it doesn't come out of my pocket or the business funds. Right now you say my entire trailer full of equipment can be replaced with 1 grand easy and that's fine if you want to work through Home Depot with bottom of the line homeowner equipment but I dare say if and when you drop 8 to 10 K on one mower your philosophy about the business will change.
Yes this is true but I have no idea how I could justify spending 8 to 10k on a lawn mower. I could get a cheaper (in every sense of the word) mower such as my honda is cheap compared to proline that I can take the risk on for a fraction of that price. I wouldn't even want to be that big enough to need something of that magnitude. I could easily drop 10k into my mortgage or a new car or another house to rent out or whatever. I am definately not disagreeing with you at all if I did spend 10k on a mower it better be dam well protected warranty insurance etc I'm just saying its not always necessary![]()
Your right this years model does come with a bag. Mine did not have a bag and could not get one they said.
When buying a mower I don't judge it on how long the warranty is. But will bring it to a shop before the warranty is up so they can go over it.
It is just faster to fix things myself
Funny! My new (right out of the box) HRR2169VKA has the same problem with the rear wheels locking up and it has never cut any grass. It's going back to Home Depot tomorrow.
