Re: MTD Yardman Transaxle Rebuild
Roger, did some quick checking on line and it seems that Sear (Craftsmen) or who ever builds those mowers use the same deck for several different models so I guess they designed and build "one size fits all" decks. It does seem odd to have 6 engine mounting holes and then only use 3 of them. I might just pull the engine off the deck to see if there are any more mounting holes in the engine itself.
Tom
That's weird to have only three bolts in the same pattern as a four bolt engine.. I figured that they would be laid out differently. (Like 120 degrees apart.)
Tom
