Re: MTD Yardman Transaxle Rebuild
Use your press to press out the sleeve you installed and try it with no sleeve just running the axle inside. If it doesn't work all you have to do is recut and install the sleeve.
Make any sense?
Tom
Tom,
Yes, that makes sense, but I would have to have a solidly mounted axel for the shive. Currently it is just a bolt run through the aluminum bracket I made. If the axle was rigidly attached to the bracket that would help, I could just leave the lock nut slightly loose and I believe the shive would rotate on it. As it is I still have to leave the lock nut loose, but that allows the bolt to tip slightly and then the face of the shive contacts the bracket. What we needed was a REAL stainless steel shive with real stainless steel bearings, not some cheap Chinese crap that rusted out in less than three months!
I could get stainless bearings and machine them into the Delrin. I 'could' do a number of things, but currently I'm busy beating myself up for being such a dumb-arse. I'll settle down eventually and do something smarter..
Roger
