Roger B
- Oct 19, 2016
- 11
- 1,656
Re: MTD Yardman Transaxle Rebuild
Tom,
I am currently rethinking the sub-float and I may settle for one that is on it's own trailer. That would simply things dramatically.. I actually have made drawings exactly as you suggested, but haven't gotten any further than that. If I build it over the yardman, that sort of makes the little tractor useless for any other purpose, (not that is has many to begin with, as the mower deck and associated controls are gone..). I think the 'skin' will end up being paper mache' painted with something to help stabilize and waterproof it.
Step son say he wants to sell his Bolens, so I've got to post something on that forum and see if anyone has a clue what it might be worth. We'd like to sell it to someone who is a collector and would restore it.
Thanks for the ideas. Right now Becky has me working on a bedroom renovation. We've got to paint the walls next and then install new flooring, but she can't make up her mind what she wants for the floor.
Rog
Roger,
Back to designing your Submarine float. Have some pictures taken of the mower with you sitting on it, side, front and rear views, print them out on a piece of paper then draw the outline of what looks like a sub over the mower and you. You are going for "the look" not a true scale sub. I figured your upper body would be inside the sail. Then draw in a couple of frames to help support the "skin" and build it out of PVC pipe and cover it with thin foam insulation. Then cover the whole thing with old bed sheets held on by painting on "Gripper" primer/sealer and when dry paint it submarine gray.
Tom
Tom,
Rog
