willys55
- Nov 11, 2016
- 8
- 1,053
Re: MTD Yardman Transaxle Rebuild
Today was productive, replaced the rear main seal, and housing gasket, replaced oil pump gasket........installed clutch and adjusted the clutch fingers.....replaced the release bearing and adjusted lever throw, bolted the two halfs back together and now I have started tearing down all the little things so that I can clean and repaint......looking forward to using it again.
might need to source out tie rods, right side is bent pretty bad
