Here is a link to test ignition suystem
Briggs & Stratton Ignition System Testing | Small Engine Repair FAQ
I removed my flywheel to clean the motor. After reassembly the motor is not getting enough spark to crank the motor. How do I test the coils?
Sounds like you need to leave well enough alone.... Did everything run great until you started messing with it?
