With a 2011 LTX1040, is there a way to temporarily bypass all safety switches so I can confirm a starting problem?
It will crank no problem, and I did pull the plug and verified it's getting spark. If I engage the blade it won't start. If I release the brake it won't start. I wasn't sure about the seat safety so I pulled the plug, no start. I then jumped the two leads with a paper clip, and no start.
All I can think of is the reverse safety. But to verify I'm on the right track I was wondering if there's an easy way at the harness in the engine compartment to just bypass all safety switches to test? No, I don't want to run it this way permanently.
FYI, the reverse light stopped going on right before it died. So I replaced the ignition/reverse switch module. Waste of $35, but at least I ruled it out.
The day it died it felt like something was grounding out. Stopped, then kept going, stopped again, and then kept going. Sort of like when you run out of gas, but I cranked it with the air filter off and oh yeah it's getting plenty of gas.
HELP! Gotta get this MTD-Cadet running soon or buy a machete for the back yard.
