Tecumseh Spark
Shay
I have the original Tech. 6hp model HH60-105079D on an old Troy built tiller with no spark. Pulled the new plug-no spark. Pulled the flywheel and inspected everything. The points look new and are perfectly clean; there were no apparent anomalies in this area. Is it possible I just need to replace the Mag? Or, replace this tired motor with a new one?
Thank you in advance for any advice.
Tim
Russ2251
...points look new and are perfectly clean...
Looks can be deceiving. My ex is an excellent example of this phenomenon.
Do you have continuity/no continuity when points open and close?
Shay
No, I never even thought to do that.
To bad this procedure won't work on women.
Thank you.
reynoldston
The points may look good but they get coated from just sitting. Points are cheap replace them if you can find them anymore?? start small then work to bigger things like coil or new engine.
Shay
Thank you. I'm considering just buying a new Briggs 900, #12S432-0036.
