Hey Everyone-
I am new here and have a question. I thought this would be easy, finding an inexpensive replacement carb for this old engine however things are not looking too good.
The number stamped on the carb is 1556E5K. Strange I cant find info on this carb using those numbers.
I have found that a carb number 632774 is a direct replacement YET when shopping for a replacement online I see some carbs which claim to be a replacement but have a prime button which mine doesnt have.
Due to my application, (restoring a craftsman LT100) one of the cheap no name carbs would be ideal JUST to prove the motor and then the transmission etc are in working order before continuing on throwing $$s into the project.
The insides of the carb look as if the previos owner of this engine stored the engine in the ocean. Its really corroded and is perhaps another project at another time.
Would anyone know of a place to get a carb that is just good enough to do the testing?
BTW, the date code on the engine is 5150 D is this an 2005 engine?
Thank you very much
Tony
Thank you very much
Tony
