D2hornets58
- Mar 4, 2012
- 25
- 288
The air intake will be the carb. Snowblowers don't have air filters, just an opening on the carb because the filters would get clogged with snow and there's very little dust in the winter time anyway. The carb is covered in a box so that the hot air coming off the engine warms the air that flows into the carb for combustion. This is to get the engine to run better with cold temps and also melt any snow that happens to get sucked in. Just do a spray or two up into that box but stand away from that area when you start it in case the engine backfires or something, you'll have a good flame![]()
OK i did see the opening in the carb. there is a knob that connects to that. Should i have the flap all the way open when running it?
Thank you for the help
