im confused,the different inlet needle caused seizure?..ran it too lean?
Seized as in "Froze up"? I don't see how an out of adjustment needle would cause a failure like that. I guess anything is possible.
D2homets 58 , if you have not pulled the carb off yet, here us what i would try first, drain all the gas out of the system, get a pt. of Sea Foam, put about 1/2 that pt. of Sea Foam in the gas tank., now fill the tank about 1/2 full with fresh gas, Now see if you can get it to crank, if it does let it run about 5 min. then shut it down and wait about 30 min. this will let the sea foam clean the carb. then recrank the motor and run a while, it should clear up and run smoth, worked for me, in the future you sould use a double dose of Marine- Stib in your gas, if there is not a fuel shut off, it would be a good idea to install a fuel shut off, when you are finished with the blower, shut off the gas and let it run out of Gas
LakeRat1
Seafoam is pretty popular and easily found. If your carb isn't leaking then $9 (at most) for a can of Seafoam just might fix your problems for the cheapest amount of $$. Worst case scenario, you still have to pull the carb and when you're done with that, you have some nice engine-cleaning gas to burn.
It might modify the octane or something to get it started easier... maybe. If you can't get it started with the Seafoam in, maybe try to get it going with a little bit of starting fluid. It's not that great to use but perhaps getting the engine to run for a few seconds might provide enough suction to get the gas flowing through the carb with the Seafoam.
