Techumceh carb. problem
Weso
Hi All:
I have a turf-trim push mower with a techumceh engine.
I need to get a carb kit but have no idea what size the engine is.
I have the carb. off but that is as far as i've gotten.
I see no info aside from mower mod, and ser no's.
Is there a way I cn find engine size?
The gas, and oil are separates but that is all I can tell you.
I have tried searching turf-trim, but not much luck.
Can someone help me please?
Thanks
Weso
reynoldston
Look on the flywheel cover and you will see some numbers stamped into it. Thet are model, type, and searil numbers. everything you will need for parts.
Find the numbers that are stamped into the carb, then go to www.partstree.com and where it says I know my model number in the first line type in tecumseh, and then put the number off the carb into the model line and it should bring up the parts diagram for the carb. If not then PM me the number off the carb and I will look it up in the tecumseh parts lookup. I can cross the number to a exact carb.
sawman024
Hello,the engine numbers should be stamped in the housing where the spark wire comes out.If needed give us the mower model and serial numbers.
