Tec AV520 no spark
Hammermechanicman
Last grasp at the straws.
I believe the engine has an external coil. If so try this. Disconnect the points wire from the coil. Connect an ohm meter to the wire from the points and to ground. Slowly turm the engine and see where the points open and where the flywheel magnets are in relation to the coil legs. Do they line up?
RevB
I have an 80's AV520 670-05F 3hp 2cycle vertical shaft engine that does not have spark.
I have replaced the coil, condenser, and points. The kill switch is good and actually not connected at the moment. The points and plug are gapped correctly, the flywheel magnets are good, the air gap is fixed on this model, I can feel the spark when holding the plug wire and spinning the flywheel by hand but when i insert the plug in the wire and ground to the engine there is nothing. I am completely stumped why I'm not getting spark. I have another same motor that gets the exact same meter readings at every point I check and gets great spark when tested by hand.
It is acting like the kills switch is connected and off even though it is not. Is there anything that could be grounding causing this no spark issue?
For about $15 -20 you can eliminate the points and condenser and go electronic. I've done this to several two stroke saws and other two stroke equipment. All ran much better with a visibly brighter spark than points due to the nature of the sharp break in the circuit that collapses the magnetic field far faster.
Just an example.
Etbrown44
I suggest you back up a few steps. Judging a spark by feel is much too subjective. Get a $5 spark tester on amazon, set it on 10 or LM, and observe your spark. You hope for bright and blue, and it's best done in a dark environment. If you want to, do the same on your other motor and you will know if the spark is equally strong. I've Been judging spark visually since 1958! Feelings are for lovers.
Mattmotors
My 2 cents. Not a mechanic but had a similar situation on a Tecumseh. My magnets on the fly wheel were strong. My neon spark tester lit up all the time (throw them right in the trash. A dog fart will light them up) but I had no spark at the plug. What I missed was one of the magnets came loose and attached to the other magnet. Once I found that, I glued it to where it was suppose to be. That engine runs like a champ now. Your magnets might be cast into the flywheel. I was also going to tell you about the points can being upside down. But you found that.
outdoorpowermike
Check wires at points and condenser to make sure they are not grounding out when cover is put back on after adjusting point gap at full open position at the point plunger. 15-17 thousand should be a good gap. Make sure wires are at correct spot at plastic bushing on point assy.
davis2
You are assuming that the old points gap was the same as what the new points gap is set at. We’re talking thousands of an inch which is very critical. I’ve seen Tecumseh engines run at point gaps ranging from .016“-.022”, depending on how the timing was set. Also, your condenser may be bad, which will also affect spark strength. I still test condensers today when ever working on these systems. Don’t need special equipment if you’re not afraid of getting shocked once in awhile. Here in Wisconsin we still have a lot of the old mule SnowKing engines being used.
Where you at in Wisconsin? I have friends in Jim Falls.
West of Lake Michigan, east of the Mississippi River, south of Lake Superior and north or the noisy state. Sorry that’s as close as you get. Got to keep some things quiet.
