Hammermechanicman
- Jan 10, 2020
- 69
- 3,939
Last grasp at the straws.
I believe the engine has an external coil. If so try this. Disconnect the points wire from the coil. Connect an ohm meter to the wire from the points and to ground. Slowly turm the engine and see where the points open and where the flywheel magnets are in relation to the coil legs. Do they line up?
