TB30R PTO won't engage
lawnguy70
Bought the mower in late May. When I push the PTO handle forward the belt does not engage. Was working fine just last week.
Model # 13A726JD023
SN: 1D200B20054
Have you checked to see if the belt has jumped off one of the pulleys?
Get down on your hands and knees and look at the belt.
lawnguy70
I removed the belt cover and the belt was on the pulleys. I checked all electrical connections and they looked fine. I started it up in low idle and the drive pulley was spinning. So I move the PTO lever and it worked fine. Not sure what happened. Must have gremlins. Thanks for the assist "Rivets".
