I removed the belt cover and the belt was on the pulleys. I checked all electrical connections and they looked fine. I started it up in low idle and the drive pulley was spinning. So I move the PTO lever and it worked fine. Not sure what happened. Must have gremlins. Thanks for the assist "Rivets".
