I agree with IL Engine, the plug not being there can cause the gov to be going to the THOR mode........LOL
Might as well get a kit since they come with a welch plug and redo the carb...... The plug is put in place and then with a punch and hammer punch it in......
BOO can you put that Nikki carb link on here like you did today for that other Nikki Carb we are helping on the Briggs section ??
That's a very detailed link for Whanner to go by ~!~!
Merci Bien Boo ~!~!~! You a great guy ~!~!
I will speak for everyone that replied to your post ,Most of us are not on here anymore , but I check in every now and then ..... GLAD the info helped out ..... I go live every now and then on my you tube channel with friends and we do the same thing on there as I did on this forum .... I go by Cajun Coin Hunter ...Mine was doing the same thing. I was lucky because when I took the carburetor off to clean it I noticed the welch plug was turned sideways and ready to fall out, If the plug hadn't been there I probably wouldn't have noticed it missing. Put it back in with a flat punch then covered it with epoxy.
