TB230 not running. Please Help.
dougand3
Yes, that's the engine model #.
When you removed the carb and cleaned it, did you remove the white Main Jet assembly? Most likely your problem is a clogged main jet. If you just want to replace it the part number is 594060 And costs about $10.00.
Tincup19
Yea I took the whole thing apart. Although I just bought the carburetor last year I’m starting to think it’s somewhere in the carb. I cleaned it again today and now it won’t even start at all. Maybe time to buy another carb and waive the white flag.
