Hello!
I have a TB30 that has given me zero problems for the last 5 years. Until today.....
I removed the deck for cleaning, re-attached the deck, and started the mower to check all the functions. Everything was good, so I shut it off.
When I went to start it up again a few minutes later, I had nothing. No clicks, no start.
I immediately checked all of the cut-off switches. (Seat, blade engage, and deck plug). All were in the proper position.
After that, I started digging deeper. I removed the cut off switches, and tested them for continuity. All good. I removed the key switch and tested it between "B' battery, and "S' solenoid. Tested ok.
I even removed the solenoid, energized it, and heard it click. I then tested it for continuity. Good.
I'm going a little nuts here. The mower is acting like one of the safety switches is not engaged, but I know damn well that they are.
Any ideas??
Any ideas??
