Taking out tree stumps
VRman
I have a Kubota BX23 and use the backhoe to remove stumps in my yard. My trees are typically in the 8-20in range. Using a backhoe can take a while, and yes, it leaves a hole. You have to have some dirt to fill in where the stump was after removing it.
I'd say, if you don't already own the equipment, going the stump grinder route is the least expensive and easiest way of doing it. :thumbsup:
